time2rollagain
Jul 22, 2024Explorer II
18' of 2/0 is still a bit far to feed 150 amps to an inverter. Have you checked the inverter input vs voltage at the battery terminals?
- captdaveoJul 22, 2024Explorer
I have, no voltage drop from the cables.
- valhalla360Jul 24, 2024Navigator
Is that measured while running? Voltage drop is a function of amperage. If the inverter is just in idle mode waiting, there will be negligible amperage draw, so there will be negligible voltage drop. Suddenly ramp that up to 150amps and there almost certainly will be voltage drop. The question is if it's an acceptable amount of drop.
