- sheldom_smithExplorerBefore calling a service guy, there are some minor issues related to Air Conditioning unit that you should keep checked atleast once a month like routine maintenance checks, which will result in a smooth and efficient running Air Conditioning unit. Lack of maintenance can lead to minor problems, which will eventually snowball into major issues that can cost quite a bit of money to repair. Frozen coils, bad fans or capacitors, dirty filters, low Freon levels or refrigerant are all issues that can arise if your AC is not routinely checked and maintained. While at first these are all minor issues, they can very quickly result in increased utility bills, excessive energy usage and damaged air conditioning units.
- ValkyriebushExplorer IIAJ's or RV world.
- mikeleblanc413ExplorerI've been in the Facebook Group, "Mobile RV Repair", for some time and have gotten good information. You might check them out. Here is the link. Best of luck!
- midnightsadieExplorer IImost roof tops are not repairable there a sealed unit, BUT it could be a very simple thing like a fan motor.
