sparkydave's avatar
sparkydave
RV outlets reliable?
After embarrassingly getting some water through the refrigerator vents while hosing off the camper and getting some water into the AC outlet, I had to take the outlet apart to get the water out as it was tripping the GFCI. I've not seen these outlets that use the metal blades that pierce the insulation to make contact before. Looks like some of the paper insulation that was part of the romex had soaked up the water and was touching the blades. I pulled out the wet paper and dried out the outlet with the heat gun, but how well do those metal blades hold up? I have little faith in residential outlets that have the spring clips where you insert the wires through the holes, and this looks to be a similar deal where the blade might eventually weaken its grip on the wire and cause hot spots.
Anybody have problems with these "vampire tap" outlets?
