desarey's avatar
desarey
RV QG 4000 Onan Generator Not Starting From Remote Panel
Hi all,
I'm perplexed with my problem and not sure how to troubleshoot any further. This generator is in a Coachman 27 foot class C coach, and the remote switch no longer starts the generator, although the remote switch does stop the generator.
I verified the remote switch is operational by using a DVM, and switching the leads to have the start work when you push the switch down instead of up.
I verified the 3 remote switch wires make it inside the generator wiring harness junction.
The generator starts and runs great when started from the generator itself.
I think this is telling me it's either the control board or the solenoid, but I don't know how to troubleshoot either.
If it is the control board, then how do I remove it?
I'm assuming the solenoid hot lead is coming from the coach batteries, and I think it would be easier to disconnect from there instead of working at the solenoid.
Greatly appreciate the help.
  • I had the same issue and mine was a rubbed through wire that i could not get to. I did a continuity test on all wires and found one not reading. I ran a new wire from the gen to the front switch. Issue solved. Like i said before if there was personal pride in the workmanship of all rv's this would not happened.
