opnspaces
Aug 25, 2024Navigator II
I'm with bid_time on this one. Do you really want to take a chance of contents of a full the black tank sloshing up the tube and greeting you when you remove the cap?
bobvila
Aug 25, 2024Explorer
This is a outside Sani Flush plug. We connect the plug with a hose water in order to spray water in the black water tank. Did the replacement yesterday and works fine. They only think I did in extra is I removed the check valve of the Inlet water plug. So when I unplug the hose, the remaining go outside as my initial San-T flush
