TKW's avatar
TKW
Black Water Tank San-T- Flush Vacuum Braker Leak
I have a occasional leak under the bathroom sink. It takes me a while to figure out it's from the San-T-Flush Vacuum Breaker. It works Ok when flushing. However, it starts to leak as soon as faucet is turned off and won't stop until the inlet hose is detached. I have it taken out to check for debris and lubricated with WD40 without success. I checked on the manufacturer's (Swan Industries in Oregon)web site, it says: "Back-seepage upon shutting off the flow of water is normal." My original thought was to give them a call for a replacement part. I now have a second thought after reading this. Am I suppose to permanently wrap a towel around it?
I read on other forum and found a suggestion to replace the plastic part with a brass one. Since I am not experience with these plastic fitting. Can anyone tell me if this plastic fitting is compatible with brass vacuum breaker? Or do I have to change the fitting as well?
Click For Full-Size Image.
