TKW
Aug 27, 2017Explorer
#1nobby wrote:#1nobby wrote:#1nobby wrote:
Since it is easy to uncouple.....just have to loosen the retaining flange nuts....or whatever they are called.....just replace it with a new one. How long did the plastic one last?
And no...it shouldn't be leaking.
Mine in brass.
My mistake.
I assumed it was the check valve for the sani flush.
I should have read the complete description.
Mine is under the lavatory sink and does NOT leak.
If yours doesn't leak, can you tell me the make & model of you brass vacuum breaker? Is it just a check valve or vacuum breaker? My plastic one combines a check valve & a plunger that shuts when pressurized, and vents when flow is shut-off. The problem is the residual pressure in the line that is not high enough to keep it shut and leaks. It only stops when the inlet hose is detached.
