k6ncx
Oct 31, 2016Explorer
Sanitizing fresh water system
We have a new 2016 Thor ACE 30.1 and I'd like to sanitize the fresh water system. All the sources say something like "mix one cup bleach with a gallon of water and pour into fresh water tank." That sounds straightforward enough, but I was (at least) two issues.
1. The filler for the fresh water tank is high up, presumably so water doesn't flow back out! I can get a funnel, but I'm not sure I can safely pour a gallon of bleach water above my head. I'm thinking it would be good to be able to attach the flexible filler I put on my potable water hose to a gallon container to pour it in. Does such a container exist?
2. That leaves the part of the system from the (separate, in fact on the other side of the rig) city water inlet to where the streams join untreated. If I had a container with a hose bib that I could put the flexible filler on, I could also put a short length of hose on it a run some sanitizing solution in through there.
Or is there a simple answer I'm missing? The simple answer we applied when in the past with an old old Santara Class C was to regard what came out of the tap as wash water only and carry many bottles of drinking water. I'd rather not continue that.
