wopachop
Jun 20, 2021Explorer
Is the fan battery powered?
If yes, it might work better inside the fridge blowing onto the cooling fins.
You need both. Fans inside the fridge. Fans behind the fridge in the vent area.
The evaporative cooler might be supplying enough air flow in the vent area. If thats the case, putting the other small fan inside the fridge blowing onto the cooling fins will help a bunch.
