mena661
Feb 02, 2014Explorer
pianotuna wrote:With enough battery capacity and solar, you could even run that 5kW load BUT how/when do you recharge for that? That's the killer. Space is not really an issue either as you COULD tow a trailer with enough batts/solar OR buy a rig that allows enough batts/solar OR make something that allows enough batts/solar (like that stacked solar panel idea you had or that guy with the toy hauler that built a battery rack under his rig).
The lowest draw I've observed in the last week is 1800 watts. It has been as high as 5000. I know my case is special--but there is no possible way I could have enough panels installed on the rv to support the heating needs.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 21, 2026
