BFL13's avatar
BFL13
Dec 31, 2016
Series 12v Chargers ?
Bestconverter ad says,
"The PD9100L Series can be wired in parallel to charge at much higher current rates. They can also be wired in series/parallel to charge 36, 48, 60, 72 and higher voltage battery packs at high charge rates"
I keep thinking about going 24v battery bank. I have several 12v converters (PowerMax brand) Reading the above, I am wondering how that would actually work.
Say I put my adjustable 100 amper and my adjustable 55 amper in series to make a 24v charger. I would want the voltage to be 2 x 14.8, so I would set 14.8 on each.
How many amps would that make to the battery bank? I am thinking 55 where you get the lowest amps (like with solar panels in series?) but that 55 with 24v is like 110 amps with 12v, so that is not too bad?
Is that how it works? Or what? Thanks.
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 27, 2025
