tomkat4725's avatar
tomkat4725
Sewer outlet lock tabs
My gray and black tanks come together in a black ABS plastic fitting which has four locking tabs which the cap or drain fitting connect to via a bayonet lock fitting. Typical on most RV's. My problem is that the plastic tabs are breaking/crumbling off. One is gone and one is partial. when I connect my drain hose I have to tie it up with a bunji cord to reduce the leaking. Do not wish to replace the "Y" fitting since this would require replacing the slide valves and elbows also. Does anyone know of a very short adapter fitting with new tabs on it which I could glue to the existing fitting? Or another method to maybe insert new tabs by drilling out the old ones and glue in new tabs? Any advice is appreciated.
