- Bill_SatelliteExplorer IISounds like a bad solution. Winegard does not appear to have been able to find a solution and is simply telling their users what to do as a work-around.
- jheppnerExplorerI'm not particularly happy with Winegard's explanation regarding their satellite dish locating the Shaw Direct satellites but here's what I was told. Go into your Shaw Direct "Options" menu on the TV screen and bring up the page showing the satellite signals. Deploy the satellite dish and wait for the satellite signals to read green and in the 90s. At this point, your Winegard controller should read "Satellite ID: 111". Immediately push the "Select" and "Power" buttons simultaneously on the controller which will lock in the satellite signal. We have used this method for weeks now and it works fine. Winegard says "With the changes Shaw made, services in the states will be hit or miss. If you can get it to work in manual, then that is your best option."
- roy67ssExplorerThe update is hardware that includes a new controller and internals in the turret. Any software would come programmed into the controller. Please let us know what Wingard says. I have heard of some dealers having issues with the new update as well.
- jheppnerExplorerWe definitely have the latest LNB, plus the new software provided by Winegard, which was installed in October. As I said, the automatic dish worked fine as we were travelling south until we arrived in the Laughlin area. Now we are still moving south and we're having to stop the dish when it finds "111". No more "automatic"! When we do this, our signals are always over "90 green" but because we're only working off "111", there are a number of channels missing, none of which affect our viewing habits, thank goodness. As soon as I get good cell phone reception, I will call Winegard to try and get some more up to date information.
- joebedfordNomad IIJust curious: you didn't state the vintage of your Travel'r. Do you have the xKU triple LNB?
- Bill_SatelliteExplorer IIThat really sucks. Please keep update once you get in touch with Winegard.
- jheppnerExplorerNo, it definitely is not working after paying for the updated software. See my post of October 19 where I've reported Winegard's solution. I've been meaning to call them to get further info but right now I'm in a bad area for cell phone reception.
- Bill_SatelliteExplorer IIIt's not working after you did the $600 required update?
- jheppnerExplorerWe're now in Parker, Arizona, and the Winegard/Shaw Direct is still not operating on "automatic" but at least we can get a signal even though there are still some channels missing. I'm not going to call Shaw Direct about this because then I might have to explain where I am.
- LwiddisExplorer IIDown Mexico way?
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
