ashnic
Oct 06, 2014Explorer
slide awnings help
Would like to order slide toppers/awnings for our Outback. We have 2 slides. Neither slide has a topper. I believe I have figured out how to measure for them however when ordering some ads are not very clear if they come with the hardware? Is there any kits that come complete? Rollers brackets bolts etc. When I order I just want to get everything I need.
Also when you screw the upper rail into the fiberglass wall of the trailer are you suppose to try and screw into the wall studs? If so how do you find them or do you just screw them into fiberglass wall?
