timaff
May 19, 2024Explorer
slide doesnt move thor ace 30.2
pictures are below
85 = white grd / i do not know where is goes (relay)
86 = yellow when engine on = 12vdc i do not know where it goes (relay)
86= yellow when engine is off = 0vdc i do not know where it goes (relay)
87a = orange black goes to center of toggle switch (relay)
30 = orange unknown and i do not know where it goes (relay)
Green yellow = (extract) from toggle switch to slide controller
Red yellow = (retract) from toggle switch to slide controller
Toggle switch wiring was checked and is good (continuity)
looking at the relay the orange should give 12vdc to the orange black lead when the engine is off. i need to find out where the orange, white, and yellow wires go and what they are for.
When engine is off 12vdc is suppose to be supplied to the orange black on the relay which sends it to the toggle switch
Problem this doesn’t happen. It is not getting the 12vdc to the orange black when the engine is off
The relay is good. I had 2 identical relays and switch them ( no difference)
i can't seem to get my hands on the correct schematic. i called thor but wasn't sent what i asked for.
bottom line there is a relay under the bed for the slide lockout. i need to find out where a yellow, orange, and a white wire go once it leaves the relay.
maybe thor will let that information out. ill call tomorrow
any help would be really Appreciated![]()
