billy1davis
Jul 13, 2018Explorer
Slide motor issues
Have 2007 Artic Fox %vr m27-5
Bedroom slide powered by Power Gear. Motor and shaft all turn fine. AF tech dept sez it must be in the mechanism. He thinks maybe a Shear pin. I can't find any where to put a shear pin except in the one end of the turning rod which I have done . All other holes have pins in them. Still no resolve.
The gear mech is very simple one track gear that the motor is suppose to turn but the motor will run fine in either direction.
Hopefully someone knows more than what I have discovered.
