electric slide motor ? Not hydraulic
there should either be a load sense circuit, like automatic steps use
or a position stop switch
which ever design is being used, it is now malfunctioning
get out the books and look it up and find the part
if she doesn't have the books, get the slide model info and look online for the service info
in the meantime, maybe replace the fuse with an auto reset DC breaker, in place of the fuse, the right size, no need to go over size and damage the motor
it will trip when you get the slide all the way in and motor load goes up, then reset in a few minutes
so the slide will go out next time
BUT find that book and the problem
before the motor is damaged and there are (2) problems
