Used MH for the last time yesterday and neither slide will move. Kinda put a damper on wk/end as we were 80 miles from home and it was raining.the HI AMP breaker was not tripped,the seat switch althou...
Most slides need to have the gear shift in park and the emergency brake set, did you have these set? Some even need the engine running. Might give that a try. What brand slide do you have?
