bob213's avatar
bob213
Slide topper tension adjustment
I have a Dometic slide topper. I did not get any info with it when purchased. There seems to be so much tension on it that it makes the top of the slide out hard to move. The slide struggles until I help it at the top to get the topper awning to start unrolling.
Can anyone tell me how to adjust the tension on the topper.
Thanks for any help.
  • TWO springs? Like one from each end? :-o Now you're going to tell me that one is LH wound and the other is RH wound.
    My topper came off at 70 mph a few weeks ago. On one end the 1/4" support rod is just a stub, barely enough to go inside the end cap. I was able to install some bushings into the end caps, to eliminate the oblong holes (more like grooves), but if I'm missing the spring on one end I might have to go topless . . . .
    Best,
    - bob
  • To adjust the spring tension(there are 2 springs), you take the end cap Arm off the mount rod and let the end unroll for how many revolutions you need. Do this with awning extended. BUT, there should never be a reason to do this. The awnings are pre-wound from Dometic with the correct tension. Is this an older RV? Was this always a problem? Sometimes the springs get rusted and will bind, but that will cause a problem when retracting, not only when extending. Doug
  • wnjj's avatar
    wnjj
    If it’s only hard to get moving at first it probably isn’t the topper causing it. As it unrolls it will pull even harder as it winds up the spring.
    Are you sure the slide isn’t mis-aligned and dragging on the opening or seals? Or did you add the topper recently?
    Setting tension on awnings can be done when the loose end of the fabric isn’t connected. Then you can just unwrap a round and reconnect.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
