- SidecarFlipExplorer IIICremating critters in the burner chamber. Cremation of insects always stinks. Have that issue with the furnace sometimes. I burn them out and they stink.
- JimExplorerBees or other vermin like to nest inside the vents for the heater. They die when you light it up, but their little bodies decompose and cause smells. Maybe that?
Also, if your heater is near by your batteries, the movement of air could be pulling out a boiling battery smell. If that's what it smells like...rotting eggs. If that's the case, could be your converter is bad and over volting the batteries.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
