christopherglen
Jan 20, 2016Explorer
A 17/18 volt panel will be great with pwm. The higher 20-30 volt panels will fail miserably with it, and will rock with mppt.
Assume the pwm controller will charge at the panels rated amperage. The mppt will (attempt) to convert excess voltage into current (amps) going into the battery. The higher the excess voltage, the more current it can convert. A 20 volt panel may generate 10% more current on mppt, a 30 volt panel will be closer to 50+%.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
