DAS26miles
Dec 18, 2015Explorer II
When using those calculators, do you use 12 volts or 17 volts which is the output voltage from the panels to the controller. The wires from the panel to the controller are the longest length. It's going to be the panel output right? And from the controller to the batteries is going to be the limit set in the controller like 14.6 volts bulk charge and 15.5 volts equalization????
