Muddydogs's avatar
Muddydogs
Solar combiner box.
Anyone have some pics or links to a DIY solar panel roof mounted combiner box?
My solar is acting up and not charging, I think its the quick connects coming off the panels to the main line on the roof. Figure I need to remove the quick connects and either solder the connections or run them into a combiner box. Since I need to mess with the stuff on the roof I might as well add another panel for a total of 3 at 300 watts so 3 lines coming into the main line is probably to much to solder together plus if I need to replace a panel having all 3 connected together would be a pain so I might as well just add a combiner box on the roof.
