BFL13
Aug 09, 2020Explorer II
Solar Controller Wiring Mystery
Friend here in the off-grid campground had his controller wired weirdly, but said it was working until a wire fell out (it was a loose screw). I am his "tech guy" so was asked to fix it.
The PWM controller was re-wired (by somebody else!) since I saw it last summer, so that in the Array pair was Array Pos in the Pos and Batt Pos in the Array Neg.
The Array Neg was in the Batt Pos (but had fallen out so nothing worked now) and the Batt Neg was in the Batt Neg.
He said this was all working up till then, and he saw over 13 volts on his battery many times while on solar this season. I thought this would be impossible wired like that.
I fixed it so the array was on the array terminals and battery on the battery terminals, and it all works.
So how could it have worked before? All I can come up with is that made it "array-direct" with no voltage limitation, and he was just lucky it did not over-voltage with his set-up of a smaller solar set (one 130w flat on roof )and fairly high demand on his four 6s.
My brain is too scrambled to figure out if that is how it was or what the heck. Can anybody explain?
Thanks!
Thanks!
