PCarnathan
Feb 19, 2015Explorer
Class A DP Trailer Brake Controller Wiring
We have a 2009 Mandalay 43A, and I need to install a trailer brake controller. The rear of the coach has a seven-pin connector, but there's no controller up front. I realize unless you have the same coach you won't know exactly, but is it customary for the manufacturer to pre-wire for the controller? Is there a special code for wire colors that could help with my search? The owner's manual is virtually worthless.
I'm sure most of you have owned your class A's for a while and I'm leaning on you and your knowledge.
Many thanks in advance,
Pat in Menifee, CA
www.patcarnathan.com
Pat in Menifee, CA
