64thunderbolt
Jan 31, 2015Explorer II
Solar Kit
Just received my kit. 2 100w panels with a 30a pwm controller. Hoping it will recharge my 2 GC2's. I am alone in the trailer and power use is min. Any thoughts?
DAS26miles wrote:
Update on my solar suitcase kit. I found that the 2 panels 50 watts put out max 5.5 amps at the house batteries. Of course this is without any load from the motorhome to take away the amps charging the batteries. I purchased an additional 30 watt panel. It came with cable and separate section with alligator clamps. I cutoff the alligator clamps and attached the short cable to the panel input connectors at the controller. Now I can easily attach or detach the cable as needed for additional panel use.
I ran my house batteries down 15 amps on my Xantrex battery monitor. I Disconnected all power from the batteries and attached the 100 watt suitcase kit. I let it run for a few minutes and it got up to 5.5 amps at the batteries per my Xantrex battery monitor and my clamp-on amp meter. I then attached the 30 watt panel and the amps jumped up to 7.5 amps, also verified on the battery monitor and clamp-on meter. I let it run and came back to check on it. The voltage climbed to 14.6 volts on the controller for panels and batteries. I checked at the batteries and got the same amps, but the volts were 13.7 volts.
I let it run some more and the controller amps dropped down to 5.5 amps and the volts remained at 14.6. I disconnected the 30 watt panel, and the amps stayed the same 5.5 amps. Interesting, the second panel does nothing to add once the amps dropped down to the 100 watt suitcase max output. Also, the voltage did drop by .2 volts.
The new 30 watt panel along with the suitcase kit fit nicely under the dinette seat out of the way. I think I made a good choice.
waynefi wrote:
I had removed a battery from the TT and set it on my porch while doing the experiment, so no other loads. I have set the timer to 180 minutes and the boost voltage to 15.
I did notice that the controller displays both panel and battery voltages, and I was looking at panel volts.That accounts for 0.1 of the difference, and now my DVM agrees with the controller measurement.
There is a fuse and an SB50 connector in the line, I'm not sure how much drop they contribute. The wire is marked as 1.5 mm2, so I think that is an area, not a diameter. I'm not sure what wire gauge that is.
I will probably re-wire with thicker wire.
DAS26miles wrote:
Waynefi-The cable used on the suitcase is 1.5mm or 15awg. I'm going to rewire mine from panels to controller with either 10 or 12awg. But the will use 10awg for the run to the batteries. If I move the controller to the MH, then I will use 10awg for that long segment.
Will look at the parameters tomorrow and see what I can change. That 120 minute timer on the boost should be changed, are you using 180 minutes?
Do you have anything running while the panels are charging? I found a drop of .6 volts which was from my fridge and parasitic stuff. Once I turned it off, the volts went up to -.1 volts below that of the controller.
SkiSmuggs wrote:DAS26miles wrote:
What ever happened to the OP 64Thunderbolt. Sorry I ran off with his topic.
That is okay. He started a good topic and it grew and I'm sure he has learned like we all have. :)
DAS26miles wrote:
Ran a test today. Drained house batteries down 20 amps. Kept fridge running on propane. With fridge going and parasitic drain the draw is .6amps. Connected panels and end of day there was still 5.0 amps down. Panels went into float with .2amps charging at 13.2 volts.
I disconnected panels and started generator. When it settled in it was charging 5.0amps at 14.2 volts. Ran the generator for 20 minutes and the battery monitor showed 3.7 amps down.
So the panels are shutting down too soon before the batteries are fully topped off. The max voltage I saw on the controller was 14.4 volts.
Something I didn't consider was the basic draw of the fridge etc from the panels output. Thus max output of 5.8 gives me only 5.2 amps charging.
Tried to change charging perameters but didn't work. Hope Solar 30 controller will work better.
