MONTANAcmpr's avatar
MONTANAcmpr
Solar panel battery problems
I purchased a basic Windynation solar panel kit and installed it on my 26ft trailer this spring. It came with a basic controller with LED light showing if the current coming from the panel is good and if the current to the batteries is good. on the 3rd day of our trip the power started dropping in the batteries and that night the batteries were completely dead. The next day the controller showed output to the battery was cutoff and the input from the panel was good. Also around the mid part of the day the battery display in the trailer showed completely charged and the solar panel showed good for panel input and battery output. One hour after sunset the batteries are dead again. I checked every connection and fuse from the controller to the batteries and they are good. I switched batteries with the same result. I'm beginning to think the controller is bad. Please help.
Having RV issues? Connect with others who have been in your shoes.24,276 PostsLatest Activity: Jun 26, 2025
