naturist
Jan 12, 2020Nomad
BFL13 wrote:naturist wrote:
You will note that they have MC4 connectors on them. Those connectors are one male, the other female. It is impossible to connect them wrong because of the MC4 connectors. That is why they are there in the first place. But also, a VOM will confirm they are wired correctly.
If you use the clips as I linked above, and put them on the wrong wires going to the controller, you can end up with them reversed. Those little monsters take a bit of figuring out. :(
Once they are on you can't get them off either. The pin grabbers mean once in, they stay in. It is an IQ test. If you fail the IQ test you buy more clips!
Funny, I've had no trouble distinguishing the male from the female MC4 connectors, nor for that matter, taking them apart after once putting them together. All you have to do is squeeze at the right spot, and they come right apart.
As for at the controller, when you make your own connectors, you certainly can put the wrong MC4 gender plug on there. One must certainly pay attention. But I defy you to plug two males or two females together. Homosexuality just isn't a thing with MC4 connectors.
