pigpen1003
Oct 03, 2020Explorer
solar panel wiring to 12v batts
I have two 6v batteries wired in series to make 12v. I have a 12v solar panel and I need to figure out how to wire them together. The solar controller has a solar panel in light, and a batt out light, plus charging light. when I hook up controller to solar panel I get strong lights. but when I connect to ground on the first batt and plus on the second batt the lights go out on controller. Am I still charging? does the solar only work on parallel connection? if so the batts would only be 6volts!
