swimmer_spe
Oct 29, 2022Explorer
Solar power
My 2023 Cherokee Wolf Pup 22RR has a factory installed solar panel. Realistically speaking, can the trailer be used with the single battery installed without it dying? I am thinking of installing a...
swimmer_spe wrote:pianotuna wrote:swimmer_spe wrote:
OP here.
I plugged it back in. It rebounded to 11.9V
I now know.
Do you mean you were charging it? Or just measuring the voltage (at the battery posts would be preferred.
40% is a bit too low.
I was reading off my panel in the trailer. The rebound I am assuming was due to the solar panel. Not bad, but definitely not good.
