allen8106's avatar
allen8106
Solar Wire Management
For those of you who have installed solar on your RV I would be interested in hearing what you have done with the rooftop wire management issue.
I'll have four panels with two #10 wires each needing to run between 10-14 feet to the combiner box so a total of eight #10 wires to manage. Outside of the obvious "conduit" answer what have you done to manage these wires? I'm planning on a tilt option so any wire management scheme needs to consider this issue.
Thanks in advance for your inputs.
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 27, 2025
