towpro wrote:
I am only buying 200w of solar. Charger is rated for 30A. Do I use 30A fuses (or breakers) or would you use 15A (which is more than I expect the panels to put out).
Between PV array & Controller: use series fuse rating found in panel specs (or
on the panel itself) . . . probably 15A . . . use
one of these for each panelBetween battery bank & Controller: breaker size = 1.56 x Output Current (so 30 x 1.56 = 47A. Since MidNite's breakers are rated for continuous current, I think you can use 1.25 multiplier instead.
Regardless, check out the
MidNite Solar Forum for info.
