Muddydogs's avatar
Muddydogs
Solar wiring question
Currently I have 2 100 watt panels on top of the trailer (VOC 21.6 volts, ISC 6.34 amps, VPM 17.4 volts, IMP 5.75 amps) with a 30 foot run of 12ga wire to the charge controller.
Last fall my system stopped charging and upon inspection one or more of the MC4 connectors are not making a good connection. My plan is to remove the MC4 connectors and make a water proof bus bar box on the roof to connect the panels to the main line.
I was thinking when I was up there that I should install a third panel. From what I can tell if I'm running the numbers right the 12ga wire will safety handle the max output from 3 panels but my line lose is high. If I switch the 30 foot of main line to the controller to 10 ga am I really gaining a lot with line loss? Will I be getting anything extra by adding a 3rd panel?
Looking at a wire table it appears that even going to 4ga wire won't get me down to a 2% loss for my run length.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
