BFL13 wrote:
My new 230w panel with the fancy MC4 3ft long wires as pigtails, turned out to be those wires are 12 AWG aluminum, not copper, when I snipped them off shorter.
So not too impressed with that. I like the other panels I have/had with a junction box and terminals in it that you attached your own wires. Then you knew what you were getting.
On that, when you buy the fancy 25 ft or whatever long MC4 cables to plug your fancy MC4 panel pigtails to, are they also aluminum? So what is their real AWG value? Phooey. I will stick to doing my own wiring; at least that way I know what is going on.
Hrm these are good things to know. I just picked up my MC4 cable and it is 10gauge. But i didnt look to see if it was aluminum I assumed copper. I haven't received my panel yet, should be here monday. Now im interested to see what the pig tails on it are.
Yes this whole battery location vs solar location and how to connect the two is giving me a headache. One thing is that I haven't actually mounted my new GC2 batteries yet. So i have had the option to consider wiring them to the back bumper. As another poster mentioned AGM woulda been brilliant because I could have put them under the kitchen seats. But with these flooded cells they have to go either on the back or on the front. It seems that the front is the most likely choice. I am a bit concerned with tongue weight as my trailer is right on the edge for my vehicle. But I am only towing it 10miles or so from its storage location to where ill be using it. Im not planning to haul this across the country so it should be ok.
