dougrainer
Jul 17, 2021Nomad
Huntindog wrote:Terryallan wrote:
Lots of people talking about the battery. So the question is. Was it plugged into shore power? If it was. Then the battery is not the problem. It will work with a dead battery, or no battery if plugged to shore power.
Not always. One of my TTs actually had a warning sicker next to the slide button stating that a battery was required for slide operation,
The reason is simple. A slide can draw more amps than the convertor is capable of.
CORRECT. Lots of slides pull a lot of amps and the Power Converter CANNOT supply the amps(power) required to operate a motor driven slide room. Doug
Having RV issues? Connect with others who have been in your shoes.24,216 PostsLatest Activity: Mar 15, 2025
