wa8yxm
May 20, 2020Explorer III
If you can get into the utility tunnels (A riser that runs along one or both side walls from there the world is your oyster. follow the tunnels to where the water lines pop through to the basement then you can cross over in the wet bays if you need to (or just compartment to comprtment along) and then up to the Furnace... NOT through the same hole as the propane line (drill a new one if you must) or even come up and enter from the side. Lots of options with not much drilling and no holes where anyone can see 'em.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
