rhingst's avatar
rhingst
Spendide 2100XC cleaning procedure
Do this if your washer/dryer is not drying as well as it should. Someone on the NUWA owners forum posted this procedure for cleaning out lint from the washer. My wife did it and it dries much better now with more air flow out the dryer vent. After the first cycle their was probably 2 cups of lint in the drum of the machine.
1. Start the unit without clothes and with the dry time off on cycle #11.
2. When the water stops entering the unit, push and hold the start button until all the lights come on then release the button.
3. Move the cycle knob to cycle #2
4. push the extra rinse button then
5. press the start button once (do not hold) then let it run through that complete cycle.
Do this 3 times then try the dryer. This system cleaning process will take the better part of one day.)
1 Reply
  • I received the following from Westland Sales on 9-11-2013. It is like the original post, but the first step is to be repeated until the tank is at least half full. In my case it usually takes me 3 times to get the tank half full.
    Copy from Westland Sales email:
    1. Start the unit without clothes and with the dry time off on cycle # 11. When the water stops entering the unit push and hold the start button until all the lights come on then release the button. *NOTE: If the water is not at least half way up the glass repeat this step.
    2. Move the cycle knob to cycle # 2 push the extra rinse button then press the start button once (do not hold) then let it run through that complete cycle.
