MaverickBBD
May 21, 2015Explorer
According to Splendide the number 1 cause of failure to dry is a clogged dryer hose. You might also find as I did that there was way too much hose. You should be able to go all the way to the drum from the rear. Have some one shine a light as you look inside the drum as you rotate it by hand. Of course make sure the hose is clear.
Having RV issues? Connect with others who have been in your shoes.24,213 PostsLatest Activity: Mar 13, 2025
