ndrorder
Jun 27, 2019Explorer
You never know, you might get lucky. Often it seems that the short will occur from the a chaffed hot wire contacting ground. Hence shorting whether the bulb is present or not. Look for chaffing anywhere the wire goes through a hole in the frame.
