wa8yxm
May 31, 2018Explorer III
Question .. Why do you need to twist the dial and. HOW FAR
THere are many 12 volt DC "Servo motors' some are "Linear" some are rotary
Screw a rod (Arm) onto the knob or attach by whatever means needed for small turns (like 90 degrees or less) and mount teh LInear push/pull motor (like a door lock motor from a car) to move the thing through a linkage.
or use a Stepper motor for up to 360 Degree movement and an Ardrino to controll it.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
