waynefi
Aug 05, 2022Explorer
stuck slide
The slide on my brand new trailer is stuck in the out position. When I tried to pull it in, the back end moved, but the front end did not. After a few back and forth tries, neither end moves. My...
mbopp wrote:
You'll need to access the dead motor from the outside, loosen a set screw, and lift the motor up to be able to push the slide in if it's a Schwintec.
