Chris_Bryant
Mar 04, 2019Explorer II
That’s basically a mechanical valve- if the pilot stays lit in the “on” position, the electrical safety fuse is fine, it interrupts the thermocouple current which holds the safety open..
Are you sure the shaft is actually turning when you move the temp adjustment? I’ve had them freeze up so moving the adjustment doesn’t move anything.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
