truthsmiles
Mar 04, 2019Explorer
Old-Biscuit wrote:
Gas tube/orifice blocked....remove/soak in alcohol--blow with LOW pressure air (High Pressure Air or poking things thru orifice will cause damage---it is a metered hole)
Gas control defective---replace gas valve
Thanks for the reply!
I've already removed and inspected the gas tube and orifice - both were clear, I could easily see through and easily pass 'breath' through. There were cobwebs in the burner tube, but gas wasn't even making it out of the orifice.
Is there any hope for servicing the gas valve? I'm still suspecting the thermistor. I know it's not 'normal' to replace it, but I'm down to give it a shot if it'll save me $150. :-)
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
