- RoyBExplorer IIIMy hot water heater doesn't like the cold weather very good... I hear it making multiple trys to fire when the temps are real cold.
When we first hookup and turn on propane, we always run the stove burners for a minute or two to bleed the lines real good...
Roy Ken - Old-BiscuitExplorer IIIRemove the burner tube...the main orifice is right on gas valve where burner tube connects.
Remove the orifice and clean it with alcohol.
If you still have a small flame after cleaning then gas pressure is low or gas valve is faulty. - TamnativeExplorerI had a similar problem,the orifice needed cleaning.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 07, 2026
