Gaetan_le_kaki's avatar
Jun 01, 2021
Sunburst classic awning
Hi all,
I have bought a 28 feet 1988 Triple E Class C (Ford E350) and I need to change the right (or front) awning spring assembly kit (the one with the tension).
The only info available on the vertical "arms" is a sticker saying Sunburst Classic.
We cannot find much on Internet. And when we call RV parts they ask us if it is a Dometic or Carefree brand? Anybody has an idea? Thanks
  • Thank you for the info. The fabric was changed and is almost new. Never thought it would be such a problem!
    Will think about changing the whole thing then although not the best for the environment but there does not seem to have any other solution.Thanks again!
  • Triple E's were Canadian built. The Sunburst was an Aussie built awning. It is neither Carefree or Dometic. Back in the 70's and 80's there were about 6 or 7 RV awning makers. By the end of the 80's it had whittled down to 2---Dometic and Carefree. It is amazing that after almost 35 years the awning FABRIC is still in good repair. If so, then try to find a supplier. With the right costing over $200 plus shipping and the LEFT costing more than $175, (you may need both) it would be better to replace the complete awning with a manual Carefree or Dometic. A Manual complete Dometic would be about $700. Doug
    https://www.aussietraveller.com.au/products/caravan-awnings/spare-parts/sunburst-caravan-awning-replacement-parts?p=2
