noplace2's avatar
noplace2
Sunchaser (Dometic) Awning Parts
Anyone know if the retaining pin (the one that pops into a hole in the awning arm) can be replaced without replacing the entire lift handle?
Thanks in advance.
  • If you can find a used pin that isn't already broken,(chances are it soon will be) then yes you can replace the pin but you have to drill out the rivit that holds it in place on the handle (2 locations old and older) and then find and install the replacement. I've yet to find a supplier that sells just the pin/rivit as new parts. That doesn't mean there isn't one.
    Something like this:
    http://anyrvparts.com/ae-dometic-3314069000b-awning-lift-handle-white
    No affiliation, just information, is your best bet. You'll need 15 minutes, a small drill motor, (1/4" drive) a sharp 5/32" drill bit, and a rivit gun to complete the installation.
    Chum lee
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
