kfp673's avatar
kfp673
Jul 10, 2021
Super frustrating AC issue
Hello All,
Please help if you can because I am about to light my camper on fire and push it off a cliff I'm so frustrated!
My camper came pre-wired for a second AC (direct vent). First AC is a Coleman Mach 15K so I purchased another Mach15 for the master bedroom. After 5 hours of install for me and a little help from my wife I got the job done. Toughest part was getting it up there but we got it. Installed everything exactly as directed. Moment of truth.... fan but no compressor. No matter what setting I chose I cannot get cold air. Fan turns on every time and even the heat strip I bought with it had no problem heating but no cold air. Checked the harness that plugs into the controls and even pulled apart the entire upper unit to look or a lose wire or something obvious. Nothing. Last ditch effort was to try my generators for power since my shore power at home is a standard 20A 110 outlet (though that has no problem running the other AC by itself). Tried the generators (which also run the other no problem) and same result. If this thing is dead and I have to replace the unit I think I'm going to lose my mind. Wasted all day today for nothing!!
If you have any suggestions please help. We leave next Friday for a week in SC which pushed me to do this install this week. Thanks in advance!
