Shelborne
May 13, 2017Explorer
Surburban SW6D 6.0 G Water heater turning off after 3 min
Hello everybody, I have a question about my water heater.
I have a 2007 Northwood Nash 17 C with a suburban SW6D 6 gallon water heater.
It has been acting extremely strange. I had problems with it last week, when I pressed the on button the light didn't come on, and nothing would happen. Then, it came on sporadically but then shut off and wouldn't come back on.
Yesterday, it turned on and then off after about 3 minutes, and today it did the same. Last night I was frustrated, so I went to bed, and then turned it on when I got up, and the red light came on and it ignited but went out again after about three minutes.
I have plenty of propane, and other appliances in my RV are working fine on propane.
When I press the on button now in the RV, nothing happens. There is no red light, nothing clicks.... etc... it just seems dead.
I have checked for loose wires, but everything looks fine. No rust anywhere that I can see. Everything looks great.
Water tank is full and cold water is coming out of all hot water taps.
I have checked the reset buttons, and nothing is tripped. I have checked all fuses.
When I open the relief valve a little bit of hot air comes out, but that's it. It doesn't stay lit long enough to begin sweating on the outside.
I repaced the igniter last week after this started happened but it doesn't look like it solved the problem I was having.
Does anybody have any suggestions?
I'm still dealing with the refrigerator issue, so I have packed ice on this trip. These occurances are wearing me out.
Although the coach is a 2007, it's probably only been used a total of seven times, and I bought the unit new. It has sat for 6 years and I bought it in 2008.
THANK YOU! Any help would be greatly appreciated!
