Bigfoot2005's avatar
Bigfoot2005
Surface and Terminal Mount Fuse Blocks
Has anyone used one of these for the fuse protection in an Inverter install?
Fuse Block
  • Yes I use the type of fuse you ask about.
    I think the're great. No additional wiring.
    Just bolt it to your deep cycle battery, hook the cable to it and you're done.
    Richard
  • RoyB wrote:
    I like anything made by BLUE SEA...
    I don't like to put more than two ring terminals on a stud bolt... If you are planning on having several rig terminal connections then a Blue sea Terminal Strip would be the thing to use as well so that no more than two ring terminals are used on one stud connection...
    Google image
    Roy Ken
    No, I would only use 1 fuse for just my inverter. I am just wondering if this type would work instead of using a ANL or T class fuse.
  • RoyB's avatar
    RoyB
    Google image
    Roy Ken
  • Some B+ vans and Tiffin motorhomes uses those 300 amp types for the Inverter AND heavy amp charge circuits. Doug
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
