Chinolbz
Jul 17, 2016Explorer
Swap to residential refer
So, I'm that close to swapping to a residential fridge. I have the semi-standard Dometic 8 cuft, 60"x24"x24". Most of the 110v models in the 10 cuft size have really bad reviews. What are you all using and how has it worked out so far? Do you block off the side and top vents? How do you insulate or cover any side, top, and bottom spaces?
Do you disconect the defrost heater, or? Thanks Chino
